Duran
Jun 20, 2018Aspirant
R7000-V1.0.9.32_10.2.34 update corrupt, cannot re-install even with recovery procedure
Hi there.
I recently launched a firmware update frmo the web interface (did it several times without any issue).
This time the process did not complete properly and the power led started flashing...
- Jun 21, 2018
> Yes I can ping 192.168.1.1 [...]
That all sounds good.
> [...] The above discussed procedure (link) refers to a TFTP client for
> the mac which I downloaded. [...]
> https://community.netgear.com/t5/x/x/m-p/1533866
I'd try the command-line TFTP client program. At the very least, its
error messages might convey more useful information than "type 50".
antinode
Jun 20, 2018Guru
> [...] I then applied the recovery procedure sending the firmware by
> TFTP [...]
That's a very terse description of a multi-step procedure with many
variables. One example (of many): Which file did you try to send to the
router?
- DuranJun 20, 2018Aspirant
Sorry for the missing details.
I connected with a cable form my mac.
I have been able to set a static ip address and the corresponding subnet mask.
The connection to the router worked properly (password) and the transfer started normally and lasted quite some time before I got the error message.
I tried both following files : R7000-V1.0.9.32,10.2.34.chk and R7000-V1.0.9.28,10.2.32.chk and it ended up the the "Error: An error of type 50 occurred" message.
Any suggestion?
- antinodeJun 21, 2018Guru
> [...] I have been able to set a static ip address and the
> corresponding subnet mask. [...]
What, exactly, did you set where? Does a command like "ping
192.168.1.1" get a response from the router?
> The connection to the router worked properly (password) [...]
What, exactly, does "The connection to the router" mean to you? Were
you using some downloaded TFTP client program or the built-in
command-line TFTP client program?
"(password)"? The first "T" in "TFTP" is for "Trivial". So far as I
know, TFTP does not use a password. That's part of "Trivial".
> I tried both following files : [...]
A ".chk" file is the right type.- DuranJun 21, 2018Aspirant
Yes I can ping 192.168.1.1 (set my own IP to 192.168.1.95 and subnet mask to 255.255.255.0)
The above discussed procedure (link) refers to a TFTP client for the mac which I downloaded.
To connect, you provide the IP, password (used the default factory password of the router, as I had done a factory reset) and a file to upload (see attached screenshot)
