Duran
Jun 20, 2018Aspirant
R7000-V1.0.9.32_10.2.34 update corrupt, cannot re-install even with recovery procedure
Hi there.
I recently launched a firmware update frmo the web interface (did it several times without any issue).
This time the process did not complete properly and the power led started flashing...
- Jun 21, 2018
> Yes I can ping 192.168.1.1 [...]
That all sounds good.
> [...] The above discussed procedure (link) refers to a TFTP client for
> the mac which I downloaded. [...]
> https://community.netgear.com/t5/x/x/m-p/1533866
I'd try the command-line TFTP client program. At the very least, its
error messages might convey more useful information than "type 50".
Duran
Jun 21, 2018Aspirant
Yes I can ping 192.168.1.1 (set my own IP to 192.168.1.95 and subnet mask to 255.255.255.0)
The above discussed procedure (link) refers to a TFTP client for the mac which I downloaded.
To connect, you provide the IP, password (used the default factory password of the router, as I had done a factory reset) and a file to upload (see attached screenshot)
antinode
Jun 21, 2018Guru
