pkaytes
Feb 12, 2022Guide
R7000 VPN not working on V1.0.11.128
I just noticed that my the OpenVPN server in my R7000 is no longer working. I can no longer connect to my private network from the internet. I checked the advanced, VPN service tab and the servic...
- Feb 15, 2022
Hi Dexter,
Thanks for the suggestion.
This is a classic case of "user error"... My error :(
I had done a factory reset just before upgrading to 1.0.11.128. When I manually re-entered the settings, I forgot to change the transport protocol from UDP to TCP.... Duh no wonder I was getting connection refused! Once I re-enabled TCP, the vpn is working again.
Pete
DexterJB
Feb 14, 2022NETGEAR Moderator
Hi pkaytes, please try updating to the latest firmware version (1.0.11.130) and check if the issue will persist. If it does, please try resetting the router and reconfiguring from scratch instead of reloading a previous config file. Let us know how it goes.
Dexter
NETGEAR Team
pkaytes
Feb 15, 2022Guide
Hi Dexter,
Pete
- FURRYe38Feb 16, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
