pkaytes
Feb 12, 2022Guide
R7000 VPN not working on V1.0.11.128
I just noticed that my the OpenVPN server in my R7000 is no longer working. I can no longer connect to my private network from the internet. I checked the advanced, VPN service tab and the servic...
- Feb 15, 2022
Hi Dexter,
Thanks for the suggestion.
This is a classic case of "user error"... My error :(
I had done a factory reset just before upgrading to 1.0.11.128. When I manually re-entered the settings, I forgot to change the transport protocol from UDP to TCP.... Duh no wonder I was getting connection refused! Once I re-enabled TCP, the vpn is working again.
Pete
pkaytes
Feb 15, 2022Guide
Hi Dexter,
Pete
Feb 16, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
