desert
Jan 18, 2016Tutor
R7000 VPN
I have been searching for for a few weeks. I am frustrated so hopefully someone can answer this for me once and for all. If I am running a VPN (OpenVpn) with the R7000 - what kind of speeds ...
- Jan 19, 2016
Yup.
TheEther
Jan 18, 2016Guru
You could always try 3rd party firmware, like DD-WRT, Asuswrt-Merlin, or any of the Tomato releases. They should all support OpenVPN server mode and, maybe, are faster than stock.
desert
Jan 18, 2016Tutor
I am running DD-WRT (Kong) already. I am at a loss what to do at this point.
- TheEtherJan 18, 2016Guru
What are the CPU load averages when the OpenVPN session is up and saturated with traffic? You can see the load averages at the top right corner.
- desertJan 18, 2016Tutor
I am downloading three 2GB test files at the same time. This is what I get.
load average: 0.61, 0.47, 0.29edit: I have seen it hit 1.00 then drop right back down to 0.71. The first number always stays around 0.61-0.71- TheEtherJan 18, 2016Guru
How long did you wait before checking the load? The first load number is averaged over 1 minute, so you'll have to wait at least 1 minute to get the true measurement.
