RSM52
Dec 11, 2016Tutor
R7000 Vulnerability - When will new firmware be released to address this?
ZD Net is now recommending that we shut down our R7000 routers until Netgear generates a fix to the exploit code that was recently released. As shutting down a router is not a reasonable option I wo...
- Dec 14, 2016
Hi All,
The Security Advisory for VU 582384 has been updated.
Also, for more information see the link below.
TheEther
Dec 11, 2016Guru
mdgm-ntgr
Dec 12, 2016NETGEAR Employee Retired
The Security Advisory has been updated with more information and beta firmware for some models. Thanks for your patience.
- AtrumDec 13, 2016InitiateI use an ARLO compatible version on my R7000, will there be an update to correct this vulnerability?
Is there already a beta version correcting the vunerability with ARLO support on the R7000?My current firmware is the R7000-V1.0.6.40_1.1.90- mdgm-ntgrDec 13, 2016NETGEAR Employee Retired
Arlo support was removed from R7000 firmware a while back now.
You can use an Arlo base station with your cameras. You can even use the new Arlo Pro base station which has a siren.- AtrumDec 13, 2016Initiate
I invested in a camera arlo without base station because you praised the possibility of using arlo with the R7000.
That you no longer support ARLO for the R7000 is one thing, but you need to fix at least an older firmware supporting ARLO by fixing the vulnerability. I'm not the only one to still use an old firmware compatible ARLO!
