johnkob
Dec 09, 2016Guide
R7000 Vulnerability Note VU#582384
It has been reported on various outlets that there is a vulnerability with the R7000 and R6400 routers. Please see https://www.kb.cert.org/vuls/id/582384 . The advisor reads "Exploiting this vulnera...
- Dec 15, 2016
Hi All,
The Security Advisory for VU 582384 has been updated.
Also, for more information see the link below.
bas996
Dec 10, 2016Tutor
Quite easy workaround for this vulnerability:
http://www.sj-vs.net/a-temporary-fix-for-cert-vu582384-cwe-77-on-netgear-r7000-and-r6400-routers/
This will be my last netgear product- very disappointing...
troco
Dec 10, 2016Tutor
I wasn't successful in the telnetd variant of this exploit, but was successful in shutting down the web interface using bas996's link. Thanks for link. I'm guessing the telnetd may not be successful, but apparently 'kill' is, so perhaps other commands are as well. I rarely reboot the router, so this will have to work for now.
