johnkob
Dec 09, 2016Guide
R7000 Vulnerability Note VU#582384
It has been reported on various outlets that there is a vulnerability with the R7000 and R6400 routers. Please see https://www.kb.cert.org/vuls/id/582384 . The advisor reads "Exploiting this vulnera...
- Dec 15, 2016
Hi All,
The Security Advisory for VU 582384 has been updated.
Also, for more information see the link below.
kochin
Dec 14, 2016Apprentice
Richard284
The file you downloaded is a firmware file. Ignore what Safari told you, and continue to follow the instructions on http://kb.netgear.com/000036453/R7000-Firmware-Version-1-0-7-6-Beta. Basically you log in your router via Web interface and use it to update its firmware.
- Richard284Dec 14, 2016Aspirant
Thank you
