ajcanter
Oct 07, 2015Aspirant
R7000 WAN capped
The WAN status used to say 1000M/Full (I'm on a gigabit service) and my tests were around 800 down 250 up but now it says 100M/Full, and my speeds are consistantly 94/94 mb/s. If I directly connect t...
- Oct 12, 2015
Technician came out today, and while working with the network admin group they noticed two different IPs going to the modem. Supposedly two IPs were causing a conflict. They have no idea when this happened. The issue is now resolved and I am getting gigabit speeds through the r7000 once again.
netwrks
Oct 07, 2015Master
Swap out your Ethernet cable between modem and router, to at least CAT5e. Cat6 if you have it. The two devices are falling out of negotiation. If you have done all that and still have an issue, plug your router and modem into an unmanaged 1000mb switch and test / check ports.
