ajcanter
Oct 07, 2015Aspirant
R7000 WAN capped
The WAN status used to say 1000M/Full (I'm on a gigabit service) and my tests were around 800 down 250 up but now it says 100M/Full, and my speeds are consistantly 94/94 mb/s. If I directly connect t...
- Oct 12, 2015
Technician came out today, and while working with the network admin group they noticed two different IPs going to the modem. Supposedly two IPs were causing a conflict. They have no idea when this happened. The issue is now resolved and I am getting gigabit speeds through the r7000 once again.
ajcanter
Oct 10, 2015Aspirant
I don't have a switch lying around but I did try another router with dhcp off and all nat off. With it between the modem and r7000 I cannot get any signal. I'm still thinking it's the modem and am going to wait for the technician on Monday. I'll report back.
- Babylon5Oct 11, 2015NETGEAR Employee Retired
With that router that you used, you should only connect to the LAN ports, did you?
