ajcanter
Oct 07, 2015Aspirant
R7000 WAN capped
The WAN status used to say 1000M/Full (I'm on a gigabit service) and my tests were around 800 down 250 up but now it says 100M/Full, and my speeds are consistantly 94/94 mb/s. If I directly connect t...
- Oct 12, 2015
Technician came out today, and while working with the network admin group they noticed two different IPs going to the modem. Supposedly two IPs were causing a conflict. They have no idea when this happened. The issue is now resolved and I am getting gigabit speeds through the r7000 once again.
ajcanter
Oct 10, 2015Aspirant
I don't have a switch lying around but I did try another router with dhcp off and all nat off. With it between the modem and r7000 I cannot get any signal. I'm still thinking it's the modem and am going to wait for the technician on Monday. I'll report back.
Babylon5
Oct 11, 2015NETGEAR Employee Retired
With that router that you used, you should only connect to the LAN ports, did you?
