ajcanter
Oct 07, 2015Aspirant
R7000 WAN capped
The WAN status used to say 1000M/Full (I'm on a gigabit service) and my tests were around 800 down 250 up but now it says 100M/Full, and my speeds are consistantly 94/94 mb/s. If I directly connect t...
- Oct 12, 2015
Technician came out today, and while working with the network admin group they noticed two different IPs going to the modem. Supposedly two IPs were causing a conflict. They have no idea when this happened. The issue is now resolved and I am getting gigabit speeds through the r7000 once again.
Babylon5
Oct 11, 2015NETGEAR Employee Retired
Well that’s a bit odd, significantly worse than the reduced link rate that you have with a direct connection from the R7000 to the modem. I would have expected your spare router ports to simply operate as a switch (which is what they are), especially since you disabled the DHCP server.
ajcanter
Oct 12, 2015Aspirant
- mondenathOct 14, 2015Prodigy
Glad to hear the problem resolved.
Try the new firmware out
