WaterOz
Aug 20, 2016Aspirant
R7000 WAN Port Not Working - Use LAN as alternate?
I have a problem with my R7000. The WAN port is dead. I've been using it in access point mode for quite some time plugged into one of my LAN ports, but I need to turn it back into a primary router. Is...
- Aug 20, 2016Ive never used Merlin but I believe you need to enable dual WAN mode and just use the secondary interface for your main WAN while leaving the other unplugged.
coolguy949
Aug 20, 2016Apprentice
- WaterOzAug 23, 2016Aspirant
That did it and worked!
Thank you!
(Side note, my router seems to be performing much better on Merlin that it had been before... so that's a plus!)
- Retired_MemberAug 23, 2016
Mine too, other than loosing at the settings Once while I was using/playing around with Dual WAN it's been great.
