CDean
Mar 03, 2021Tutor
R7000 Webex Issue
I can no longer connect to Webex sessions via my router. It doesnt matter if I use wifi or wired same issue. Also if my phone is using wifi it will not connect either. I get a timeout error for ta...
michaelkenward
Mar 04, 2021Guru - Experienced User
What happenes when you try?
What tells you that it is the router that is getting in the way?
Any error messages? Prompts? In what?
CDean
Mar 04, 2021Tutor
Thats for the reply.
I got it fixed !
First I connected to the Cable Modem directly and all was fine.
That put me back to it being a router issue.
I started turning off optional items in router.
When I turned off Qos ... My wired and wireless devices were able to connect to the webex test site without timing out or giving me unable to connect to server messages. .
Not sure why ???
- CDeanMar 23, 2021Tutor
I just want to post an update on this issue.
It turns out that my issues returned. Not just with a particular website but other websites as well.
I read the Netgear message Boards and found that if you Clone the Mac address it will fix this issue.
Its hard to believe but it fixed the issue instantly. I need to mention you should reboot your Cable Moden and Router after the change.
I am not sure why this issue just popped up on a 2 + year old router. Probably has something to do with Comcast !
- michaelkenwardMar 23, 2021Guru - Experienced User
Sounds like an excellent guess. After all, it is the receiving end that checks the Mac address when you connect.. And ISPs can be picky about what you connect.Nice bit of detective work Sherlock.
- Grover23Jul 27, 2021Aspirant
michaelkenward wrote:
CDean wrote:I am not sure why this issue just popped up on a 2 + year old router. Probably has something to do with Comcast !
I have a R8500 router that also has stopped connecting to Webex. I was hoping to try the solution above about cloning the Mac address, but wasn't sure how to go about that. Mind typing out a step by step guide? Thanks in advance! :)
