harrma
Jun 01, 2021Aspirant
R7000 wifi 6
On the documantation it says it supports WIFI 6 but it is wifi 5. With the router being the beginning of the WIFI line how is that even possable since it dosnt need WIFI it gives it. It ether has it ...
- Jun 02, 2021
harrma wrote:What is the difrence?
Difference between ipv6 and wireless?
Wireless is a wireless broadcast standard.
IPv6 and IPv4 are the protocol the lets machines communicate with each other. Like going from computer--->router---->modem----->isp----->website----->etc.
I linked to the wikipedia listing so you can learn more about ipv6 if interested.
Jun 01, 2021Guru - Experienced User
Where do you see in the documentation that is supports wifi 6?
harrma
Jun 02, 2021Aspirant
page 8
- DarrenMJun 02, 2021Sr. NETGEAR Moderator
I do not see any mention of wifi 6 on page 8
- harrmaJun 02, 2021Aspirant
did you look at the hilighed part from the image I sent?
- plemansJun 02, 2021Guru - Experienced User
Your screen print was a bit blury. looks like you highlighted of the product data sheet. if i pull that up, its highlighing IPv6.
Thats not a wifi standard. Its a communication protocol.
