nxi
May 22, 2017Aspirant
R7000 wifi dropping connection constantly
Firmware: V1.0.8.34_1.2.15 OS: Windows 10 x64 OS 2: Android N WiFi 2.4ghz settings Region North America Channel Auto (9) Mode Up to 600 Mbps Wireless AP On Broadcast Name On Wi-Fi Protect...
- Jun 04, 2017
Hi All,
Reset the router to factory default and manually reconfigure it.
JamesGL
Jun 07, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
ifishskis
Jun 22, 2017Tutor
Last week I took my R7000 out of service because I (and especially my gamer kids) were getting sick of randomly losing the internet connection. Would happen 3-4 times every day and last from 20 sec. to 1 minute, then "fix itself". I would always update the firmware when a new one was releaded. The new router that I leased from my ISP has worked flawlessly. My ISP has noted ZERO connection problems with the line running to our house.
So I get the restoring factory default process but can you further explain the manual setup procedure? What specific "things" (DNS, IP address, etc.) will I have to do manually? I'd like to be as prepared as possible should I deceide to go this way.
It sucks having a $250 router (purchased 2 years ago) and it doesn't work reliably!
p.s. it worked fine up until a few months ago. I blamed it on the modem but that wasn't the problem.
- JamesGLJun 26, 2017NETGEAR Employee Retired
Hi ifishskis,
You can follow this steps when configuring the router.
- ifishskisJun 28, 2017Tutor
this is how my 7000 is configured. Again, this seems to have started happening ini the past few months. I'm thinking a firmware issue?
- nxiJun 29, 2017Aspirant
I suspect it is a firmware issue too. I'm contemplating flashing the router with Tomato. I've used Tomato on another router, and it's great for a SOHO router. The stock firmware is not useable anymore.
