chopin70
Mar 19, 2018Virtuoso
R7000 wifi drops
Hi, We all know the issues with wifi and R7000. However, I was only expieriencing a few drops a day on 1.0.9.12 and decided to update to V1.0.9.26_10.2.31 - Now, every few minutes, my Androi...
- May 10, 2018
I fixed the issue, really f**king stupid fix. I had to narrow my google search to xda:
Hey everyone I was able to temporarily fix this issue by turning off wifi scanning in (Settings > Location > Improve Accuracy). I heard somewhere on here it might have been a recent app update that is causing the issue.
I normally always have this setting off. I verified, and all my devices had it on back. I guess on each Android update they try to dig again in our privacy...
Disabling it fixed all disconnections on my Galaxy Note 4. Newer devices like Android 7 and Android 8 phones have no issues with this option enabled
Hope it can help Netgear fix it also on their side. In fact, this fix cannot resolve my Android TV disconnections. A TV firmware update made things better on TV but did not fix completely the disconnections
chopin70
Apr 07, 2018Virtuoso
The FW you mention doesn't change anything
Anyway:
- after update TV to latest FW, it seems to work better, one data drop over a week, so it is not kicked off like it used to be
- Galaxy Note 4: still unusable, wifi data drop every few minutes, while connection is good, logs look as always, good. Reset phone didn't fix anything
- Other Android 7 and 8 devices are fine
I will try again longer the Note 4 on another wifi network before throwing the router through a windows :smileywink:
not to be rude, but your issue has nothing to do with what is discussed here. It is recommended to open your own thread instead of jumping in distracting from main issue
douggiese
Apr 07, 2018Apprentice
Apologies, to chopin70. I thought we were having similar issues and reporting my experimentation might be helpul to you.
