wazlecracker
Sep 30, 2015Aspirant
R7000 Wifi issues
I've had my trusty R7000 for a few months now and it's done very well, up until maybe a month or so ago. All of a sudden my wifi performance took a nose dive, however it wasn't my bandwidth, seems li...
- Oct 01, 2015
So hitting the reset button solved my issues. Now I wish I knew what was causing it. Thanks for your help!
Babylon5
Oct 01, 2015NETGEAR Employee Retired
If it is just the phone which is showing issues, then I suggest that you install a ‘traceroute’ application on the phone to determine where the delays are.
