wazlecracker
Sep 30, 2015Aspirant
R7000 Wifi issues
I've had my trusty R7000 for a few months now and it's done very well, up until maybe a month or so ago. All of a sudden my wifi performance took a nose dive, however it wasn't my bandwidth, seems li...
- Oct 01, 2015
So hitting the reset button solved my issues. Now I wish I knew what was causing it. Thanks for your help!
wazlecracker
Oct 01, 2015Aspirant
Sorry it's not just the phone, I should have explained better, my desktop is also connected through wifi and it gets weird as well.
Babylon5
Oct 01, 2015NETGEAR Employee Retired
No problem, if you think there are delays then running a tracert on a PC (or the equivalent on a smartphone) should help identify where the delays are.
- rpoffenOct 01, 2015Virtuoso
Do you have the Genie app installed on your PC (either from the included CD or having downloaded and installed it from the Netgear website)? Some have reported that this can cause issues for the router.
- wazlecrackerOct 01, 2015Aspirant
What specifically should I do with the tracert? Not sure what IP address I should put.
No I don't have the Genie app installed.
- Babylon5Oct 01, 2015NETGEAR Employee Retired
I think default values should do, so as per this example you would just use the URL of a site where you are seeing a slow response;
http://stackoverflow.com/questions/451967/what-do-the-numbers-reported-by-the-windows-tracert-mean
e.g. tracert www.yahoo.com
Here are the results, as you can see on the 12th one it timed out. Does the same on a repeat. What do I do with this info?
C:\WINDOWS\system32>tracert www.google.com
Tracing route to www.google.com [74.125.21.105]
over a maximum of 30 hops:1 31 ms 29 ms 31 ms 10.109.1.1
2 33 ms 43 ms 30 ms 45.32.128.1
3 30 ms 31 ms 31 ms xe-1-2-2.cr1.sjc2.us.as4436.gtt.net [69.22.143.237]
4 31 ms 31 ms 32 ms xe-11-3-1.sjc12.ip4.gtt.net [89.149.184.237]
5 31 ms 31 ms 32 ms as15169.sjc10.ip4.gtt.net [199.229.230.134]
6 44 ms 31 ms 31 ms 216.239.49.170
7 97 ms 97 ms 97 ms 209.85.246.38
8 82 ms 91 ms 84 ms 216.239.46.240
9 83 ms 71 ms 70 ms 209.85.240.23
10 96 ms 95 ms 99 ms 72.14.234.3
11 94 ms 96 ms 97 ms 209.85.142.153
12 * * * Request timed out.
13 97 ms 95 ms 96 ms yv-in-f105.1e100.net [74.125.21.105]
