wazlecracker
Sep 30, 2015Aspirant
R7000 Wifi issues
I've had my trusty R7000 for a few months now and it's done very well, up until maybe a month or so ago. All of a sudden my wifi performance took a nose dive, however it wasn't my bandwidth, seems li...
- Oct 01, 2015
So hitting the reset button solved my issues. Now I wish I knew what was causing it. Thanks for your help!
Babylon5
Oct 01, 2015NETGEAR Employee Retired
No problem, if you think there are delays then running a tracert on a PC (or the equivalent on a smartphone) should help identify where the delays are.
rpoffen
Oct 01, 2015Virtuoso
Do you have the Genie app installed on your PC (either from the included CD or having downloaded and installed it from the Netgear website)? Some have reported that this can cause issues for the router.
