wazlecracker
Sep 30, 2015Aspirant
R7000 Wifi issues
I've had my trusty R7000 for a few months now and it's done very well, up until maybe a month or so ago. All of a sudden my wifi performance took a nose dive, however it wasn't my bandwidth, seems li...
- Oct 01, 2015
So hitting the reset button solved my issues. Now I wish I knew what was causing it. Thanks for your help!
wazlecracker
Oct 01, 2015Aspirant
Okay so if the issue is happening to every device that connects to the Wi-Fi whether it's the 2.4 or the 5 bands it pretty much has to be the router correct? Do you think factory resetting it and putting the original firmware would help?
- Babylon5Oct 01, 2015NETGEAR Employee Retired
A factory rest would not hurt, it might help to rule out other possible issues, or more hopefully get you up and running happily again. However while the router might be a common factor for all your devices, so is anything downstream of the router.
I suggest that you save your current router settings to a file before a factory reset. After the reset manually configure the router with the minimum settings needed to check if the issue is gone, and if it has reload the saved settings and check again. If that doesn't help then consider changing the firmware.
- wazlecrackerOct 01, 2015Aspirant
- Babylon5Oct 02, 2015NETGEAR Employee Retired
That’s good, hopefully it will not be a recurring issue.
