Tweazle
Oct 31, 2015Aspirant
R7000 WiFi not broadcasting
I have an R7000 which up until now has been working really well. Last night (at about 10pm GMT) the unit shut itself off (all lights off). This morning when I looked at it I had to press the power ...
- Nov 09, 2015
Sorry to hear. I guess it's off to the nearest e-waste collection point.
mondenath
Nov 02, 2015Prodigy
yes its at the right side of the router both Button should glow. if WIFI is off both will not glow.
Tweazle
Nov 08, 2015Aspirant
Sorry, guys; have already done that too. Apologies for not mentioning it.
- TheEtherNov 08, 2015Guru
Running low on ideas. Check the antennas and make sure they are properly attached.
If the router is plugged into a power strip, try plugging it directly into the wall outlet.
Try re-installing the firmware.
- TweazleNov 09, 2015Aspirant
Yep, sadly done all that.
I'm afraid that as a lack of any further options I've moved on. Bought an Apple Extreme base station. Brilliant bit of kit. Simple, good looking and just, well, easy.
Thanks for trying guys, given up with Netgear now though.
- TheEtherNov 09, 2015Guru
