ethon
Feb 05, 2021Aspirant
R7000 Wifi Router issues with devices connecting after Firmware Version 1.0.11.116 update
After updating to Firmware Version 1.0.11.116, my devices in my house will randomly disconnect from the Router. I get logs on the device like my device was blocked due to security issues but if I re...
Feb 05, 2021Guru - Experienced User
A couple things to try.
1. anytime theres an issue after a firmware update, a reasonable first step is a factory reset and clean install (not from backup). In case an old setting is causing the issue. I'd try that first.
2. if it doesn't help, you can rollback the firmware to an earlier version. If it worked great before, you could simply go back a version.
3. If going back 1 version doesn't help, the version I'd recommend would be 1.0.9.42 for the r7000.
Any firmware changes should be done over a hardwired connection for best results.
bascaves
Feb 10, 2021Apprentice
Hello,
Hmm not encourging again..... So I keep watching the Netgear community once more.
We all know the security issues and actually we should upgrade. The bad is that Netgear since 1.0.9.42 never delivered a good and trust firmware anymore for actually a great piece of h/w. You upgrade, you pray that your R7000 doesn't brick. You downgrade again. Spending hours and hours plus frustration.
But if the ones that dare or the innocent ones report that 1.0.11.116 is the first next good release after 1.0.9.42
.... I even might find the courage again.
