Gil80
Aug 13, 2017Apprentice
R7000 WiFi schedule issues
Hi all. The WiFi schedule is buggy and I wanted to know if someone has an idea to make it work correctly. 1. The router time zone is not correct - this is just an observation. I do not know wher...
- Aug 15, 2017
Hi Gil80,
You can change the Timezone under security>schedule.
JamesGL
Aug 20, 2017NETGEAR Employee Retired
Hi Gil80,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
JamesGL
Aug 21, 2017NETGEAR Employee Retired
Hi Gil80,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- tomilieSep 02, 2017Aspirant
Hi
I have other question: can we set several schedules for wifi, by example:
- During working days : schedule 1
- During week end: schedule 2
I saw that we can set several schedule, but in column "period", we can select only one.
Thanks for your support
- amediamonkeySep 21, 2017Aspirant
JamesGL wrote:Hi Gil80,
The solution posted here does indeed work and I would happily mark it as the preferred solution. It allows the user to select which services are scheduled and I just ticked ALL to stop the kids (and parents!) accessing the internet in the night.
HOWEVER, the solution posted elsewhere on the Netgear support website does not work:
https://kb.netgear.com/24102/How-do-I-set-up-the-wireless-schedule-on-my-Nighthawk-router#
This appears to shut down the WiFi at scheduled times, but simply does not work. The GUI says the WiFi is off, but you can still happily connect to it. Correct this, then the problem will be solved.
