blobdobguy
May 29, 2016Aspirant
R7000 wifi trouble
I have a weird wifi issue with my Nighthawk. I have some devices (printer, etc) which I can only get to connect to my guest wifi. I enabled both 2.5GHz and 5GHz in different configurations, but I see...
- May 29, 2016
What are the Wi-Fi settings (SSID broadcast, security mode, speed mode, channel) on the router?
Can these devices see the Wi-Fi network? Are you prompted to enter the password when they try to join the network?
Do you have MAC address access control enabled on the router?
TheEther
May 29, 2016Guru
- blobdobguyMay 29, 2016Aspirant
SSID broadcast is enabled, security mode is WPA2-PSK, speed mode I tried them all, channel set to auto.
The devices see the network, I get prompted for the password, but they are unable to connect. The connect fine to the gues one though.
I don't have MAC address access control.
- TheEtherMay 29, 2016Guru
Try switching the channel from auto to a fixed number.
Try using WPA-PSK or WPA-PSK+WPA2-PSK security.
If the password has special characters, then try a simpler password (i.e. alphanumeric).
Thanks for the suggestions! I tried all of them but I didn't manage to get it to work. My laptop connects fine to the 5GHz network but not to the 2.5GHz one. I copy/pasted the password so that cannot be an issue. My Mac just says there was a problem connecting, while my printer thinks it's a wrong password.
