blobdobguy
May 29, 2016Aspirant
R7000 wifi trouble
I have a weird wifi issue with my Nighthawk. I have some devices (printer, etc) which I can only get to connect to my guest wifi. I enabled both 2.5GHz and 5GHz in different configurations, but I see...
- May 29, 2016
What are the Wi-Fi settings (SSID broadcast, security mode, speed mode, channel) on the router?
Can these devices see the Wi-Fi network? Are you prompted to enter the password when they try to join the network?
Do you have MAC address access control enabled on the router?
TheEther
May 29, 2016Guru
blobdobguy
SSID broadcast is enabled, security mode is WPA2-PSK, speed mode I tried them all, channel set to auto.
The devices see the network, I get prompted for the password, but they are unable to connect. The connect fine to the gues one though.
I don't have MAC address access control.
