blobdobguy
May 29, 2016Aspirant
R7000 wifi trouble
I have a weird wifi issue with my Nighthawk. I have some devices (printer, etc) which I can only get to connect to my guest wifi. I enabled both 2.5GHz and 5GHz in different configurations, but I see...
- May 29, 2016
What are the Wi-Fi settings (SSID broadcast, security mode, speed mode, channel) on the router?
Can these devices see the Wi-Fi network? Are you prompted to enter the password when they try to join the network?
Do you have MAC address access control enabled on the router?
blobdobguy
OK, I will give it a try.
blobdobguy
May 31, 2016Aspirant
This worked. Thanks for the suggestion! It's a shame I had to do the configuration from scratch though.
