jjblaze
Dec 09, 2022Aspirant
R7000 wired working, devices can't connect to wifi
Hello, This morning a weird issue popped up. All of my wireless devices can not connect via wifi. The router has the current firmware (V1.0.11.136_10.2.120). The wifi SSID are displaying, but n...
- Dec 09, 2022
Ok. Lets do a factory reset by pressing the reset button for 10 seconds then release. When the power and wifi radio LEDs turn ON, pull the power adapter for 30 seconds, then plug it back in. After the router is back to ready, walk thru the setup wizard with a wired PC and web browser at 192.168.1.1.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Dec 09, 2022Guru - Experienced User
Be sure the WiFi is enabled on the router. There is a LED button that you can press for 5 seconds then release. This should turn on the 2.4 and 5Ghz radio LEDs on top of they are off.
jjblaze
Thanks.
The 2.4 & 5GHz lights were on. I held down the (( . )) button to turn them off, the back on. Removed the SSID from my phone, then tried to reconnect with the password. Still could not connect. đ
- FURRYe38Dec 09, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.- jjblazeDec 09, 2022Aspirant
That did the trick. Thanks for your help.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
