donEddie7
Aug 17, 2017Aspirant
R7000 Wireless Issues w/ Microsoft Surface Pro 4, Works Fine w/ other Devices
Hello, I've recently begun to have issues connecting my Surface Pro 4 tablet to my home Wifi even though other devices have no trouble connecting via Wifi or Hardwired. My firmware version on my rou...
- Jun 13, 2018
Hi Keigotw,
A new firmware update is available. Please update the firmware to 1.0.9.32.
https://kb.netgear.com/000059134/R7000-Firmware-Version-1-0-9-32
Blanca
Community Team
Keigotw
Jun 13, 2018Tutor
I didn't want to try beta firmware Version-1-0-9-30-Hot-Fix
but I went ahead and installed 6/12/18 - Firmware update 1.0.9.32 last night and seems to work fine.
no issue with Surface Pro 4.
will report back if I find any issues
Blanca_O
Jun 13, 2018NETGEAR Employee Retired
Hi Keigotw,
Blanca
Community Team
- Rjp2003Jun 13, 2018AspirantI installed the latest firmware on R6900, and my surface still has internet connectivity issues.
- Blanca_OJun 14, 2018NETGEAR Employee Retired
Hi Keigotw,
Is everything working fine using the latest firmware (1.0.9.32)?
Blanca
Community Team
- Blanca_OJun 21, 2018NETGEAR Employee Retired
Hi Keigotw,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Blanca
Community Team
