bobplumb
Dec 18, 2023Aspirant
R7000 wireless network not showing up
R7000 has been working great for years. Last night I noticed the usual network was not showing up on my laptop. Cable to house good. Smart TV good, Netflix, etc. Splits to wireless router but now...
- Dec 18, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
bobplumb
I did try to power on/off last nite.
Musta hit that button as I reached over the top of the device.
Crazy I didn't check that.
All good now.
Thanks for the help!
Dec 18, 2023Guru - Experienced User
Enjoy. 📡
