VanillaSuede
Aug 07, 2015Aspirant
R7000 wireless not working
I don't know how long I've had this thing, probably less than a year, and have had no issues (from looking at these forums seems like I'm lucky). All of a sudden the wireless stopped working. In the ...
- Aug 07, 2015
and I fixed it
Amjathcool
Mar 13, 2017Aspirant
Wired connections are working, but wifi is not working. Pressed the wifi button for 2 seconds, but still wifi is not getting on. Please help in getting my wifi problem fixed.
- ArcHammerMar 16, 2017Initiate
I am in the same situation. My wifi is disable and the Wifi button press (2 seconds or longer) will not re-enable.
- JamesGLMar 16, 2017NETGEAR Employee Retired
Hi All,
Access the UI and make sure to enable router radio.
https://kb.netgear.com/24101/How-do-I-enable-or-disable-the-wireless-radios-on-my-Nighthawk-router
If still the same, reset the router.
- JamesGLMar 19, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- curryfoundationJul 22, 2017Initiate
I've tried reseting, logging on directly, though now it says I'm not on its network. Even though I'm using a wired connection. While I was logged on, I managed to select enable radio, though it still does not work. It was fine Thursday, but when I got back into town today, my wifi was just not working.
- Angelo1Sep 20, 2017Aspirant
FYI - novice computer guy. I had dead wi/fi to all devices (laptop, phones, smart TV) after a cable network outage (internet, phone, cable TV). I rebooted everything after cable access returned (turned off cable modem and router per standard procedures). Modem came back correctly, netgear router only had the power light, internet light and port 4 light were lit (ethernet cable is plugged in to #4), nothing else was lit. Tried pushing wi/fi and wps buttons in all combinations and on/off times, no luck.
I fished around the internet and Netgear support site. Ended up directed to login to the help site for my registered product Nighthawk 7000, then go to advanced settings, wireless section. I found that the check boxes for wireless (2.4 & 5 Gb) were grayed out and would not respond. Then I noticed a 'firm update available' alert for my router. I proceeded to update my system software and the wi/fi system started working fine again immediately after the update finished.
Another fyi, corded (ethernet cable to my desk top) had worked fine all along - which is how I managed to dig up the info.
