VanillaSuede
Aug 07, 2015Aspirant
R7000 wireless not working
I don't know how long I've had this thing, probably less than a year, and have had no issues (from looking at these forums seems like I'm lucky). All of a sudden the wireless stopped working. In the ...
- Aug 07, 2015
and I fixed it
Amjathcool
Mar 13, 2017Aspirant
Wired connections are working, but wifi is not working. Pressed the wifi button for 2 seconds, but still wifi is not getting on. Please help in getting my wifi problem fixed.
JamesGL
Mar 16, 2017NETGEAR Employee Retired
Hi All,
Access the UI and make sure to enable router radio.
https://kb.netgear.com/24101/How-do-I-enable-or-disable-the-wireless-radios-on-my-Nighthawk-router
If still the same, reset the router.
- JamesGLMar 19, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- curryfoundationJul 22, 2017Initiate
I've tried reseting, logging on directly, though now it says I'm not on its network. Even though I'm using a wired connection. While I was logged on, I managed to select enable radio, though it still does not work. It was fine Thursday, but when I got back into town today, my wifi was just not working.
- JamesGLJul 24, 2017NETGEAR Employee Retired
Hi curryfoundation,
Can you see the wireless network?
What is the firmware version of the router?
How many devices are affected?
