VanillaSuede
Aug 07, 2015Aspirant
R7000 wireless not working
I don't know how long I've had this thing, probably less than a year, and have had no issues (from looking at these forums seems like I'm lucky). All of a sudden the wireless stopped working. In the ...
- Aug 07, 2015
and I fixed it
gyaniboyz
Nov 23, 2017Aspirant
I have the same issue with my R7000 router. It works with a wired connection (Ethernet cable) but does not work with wifi. As with the screenshots shared by CurryFoundation; I have the same view on the router homepage. Tried all these-
- Factory Reset ;
- Hard reset (with the reset button)
- Changed the wifi SSID and pwd
- Tried checking and unchecking the "Wireless Router Radio" checkbox
- Downgraded firmware to V1.0.4.30 .
Any other suggestions that may get the WiFi working?
Thanks!
~Ganesh
OldEars
Nov 23, 2017Tutor
I did a hard reset, then restored my settings from the saved file. No love, but then I repeated the reset and it worked. Manually restored my settings one-by-one and it still works. Sorry this didn't work for you.
- gyaniboyzNov 23, 2017Aspirant
I just got it working. Here's what I followed.
- Hold hard reset for 60 sec
- Uplug the power connection for 60 sec
- Reconnect power cable & wait for lights to turn white
Now all devices are back online for the past hour. Fingers crossed for continued connectivity.
