VanillaSuede
Aug 07, 2015Aspirant
R7000 wireless not working
I don't know how long I've had this thing, probably less than a year, and have had no issues (from looking at these forums seems like I'm lucky). All of a sudden the wireless stopped working. In the ...
- Aug 07, 2015
and I fixed it
VanillaSuede
and I fixed it
pakgear
Glad to hear. What did you change that resolved the issue?
- madhatterAug 08, 2015Apprentice
probably user error
- VanillaSuedeAug 08, 2015Aspirant
Yup - user error. For whatever reason the radio shut itself off - either that or my brother (who is visiting) did something stupid to shut it off. I found it a little odd that you can disable it on the hardware but you can't reenable with the software but then again I'm the moron who just needed to push a button for two seconds to make it work - what do I know?
- VE6CGXAug 08, 2015Master
Finger problems, Eh?
Good to hear you are back on the air.
