bugs_galore
Sep 06, 2021Guide
R7000 Wireless turning off then on at the wrong times
Having a problem with wirelss schedulling with R7000 using Advanced --> Advanced Setup--> Wireless Settings I've set up start and end times, and have checked the "Turn off wireless signal by sche...
Portwey84
Sep 06, 2021Virtuoso
bugs_galore I'm genuinely interested, is there some reason you want wireless scheduling? Personally, I just leave mine on all the time.
- bugs_galoreSep 06, 2021Guide
Portwey84 - I want to turn it off at night after midnight so the kids don't stay up for hours on the internet.
The feature is working at the intended time, but the side effects are that it's doing it randomly at many other times during the day.
- bugs_galoreSep 07, 2021Guide
I have an update on this. Was looking through all the logs (Administration --> Logs), and I see that every single time the wifi incorrectly turned OFF then ON, there was an NTP synch in between the incorrect OFF and the ON (putting it right) a minute later.
And all the incorrect OFFs are tagged with the exact same incorrect time stamp: 3:29:39. Which just happens to be during my gui-entered off time.
My theory is the time in this R7000 can momentarily become incorrectly set to 3:29:29 during NTP sync.
Note this deos not happen on every NTP sync.
This looks like a bug in the R7000 to me. Would be great if Netgear can comment if this is a known bug or if any fix will come.
- bugs_galoreSep 16, 2021Guide
Is there a way to get a response from Netgear for issues like this? This one is a bug. It would be nice to have a fix for it.
