bugs_galore
Sep 06, 2021Guide
R7000 Wireless turning off then on at the wrong times
Having a problem with wirelss schedulling with R7000 using Advanced --> Advanced Setup--> Wireless Settings I've set up start and end times, and have checked the "Turn off wireless signal by sche...
Portwey84
Sep 16, 2021Virtuoso
bugs_galore I'm afraid, unless you're still on 90 day complimentary support, the only way you'll get Netgear to do anything for you, is to buy their technical support at I suspect some cost.
I can't comment further as I have had no need to do what you're trying to achieve, so I haven't even tried to replicate it.
Netgear have just released the latest v.128, so you could try flashing the firmware to see if your problem persists, but I wouldn't hold your breath.
bugs_galore
Sep 16, 2021Guide
Ha Portwey_80 - you sound almost as cynical as I am. I once used their phone technical support, and it was an unfortunate combination of painful, time consuming, frustrating and useless. So I wouldn't pay to extend it.
I will look for that new FW you mentioned and try to download it. Thanks.
