bugs_galore
Sep 06, 2021Guide
R7000 Wireless turning off then on at the wrong times
Having a problem with wirelss schedulling with R7000 using Advanced --> Advanced Setup--> Wireless Settings I've set up start and end times, and have checked the "Turn off wireless signal by sche...
Sep 16, 2021Guru - Experienced User
Well you reported in your first post:
"This R7000 is running V1.0.11.126_10.2.112 firmware"
Which is one version behind: v1.0.11.128
A reset is sometimes a valid step to help figure out issues and can lead to solved problems. Sometimes configurations can be hosed up after a FW update or configurations on prior versions are not fully compatible with new versions of FW. Maybe drastic but sometimes a necessary evil.
bugs_galore
Sep 16, 2021Guide
Looks like v1.0.11.128 was released yesterday. Portwey84 mentioned it just got released. I just checked the notes for the new release - looks like only a security fix.
But googling v1.0.11.126_10.2.112 shows there are other NTP problems in this FW, that were not there in the previous release, so maybe they might have fixed some of those issues without listing it in the notes.
- FURRYe38Sep 16, 2021Guru - Experienced User
Someting to try.
I would do a reset as well if you update to 128 and setup from scratch....
