bugs_galore
Sep 06, 2021Guide
R7000 Wireless turning off then on at the wrong times
Having a problem with wirelss schedulling with R7000 using Advanced --> Advanced Setup--> Wireless Settings I've set up start and end times, and have checked the "Turn off wireless signal by sche...
bugs_galore
Sep 16, 2021Guide
Looks like v1.0.11.128 was released yesterday. Portwey84 mentioned it just got released. I just checked the notes for the new release - looks like only a security fix.
But googling v1.0.11.126_10.2.112 shows there are other NTP problems in this FW, that were not there in the previous release, so maybe they might have fixed some of those issues without listing it in the notes.
Sep 16, 2021Guru - Experienced User
Someting to try.
I would do a reset as well if you update to 128 and setup from scratch....
