djchap
Dec 23, 2020Aspirant
R7000 with Raspberry Pi zero-w Pi-hole
I intend to setup a Raspberry pi zero -w with pi-hole for DNS serving on my r7000 network. Pi is powered via mini USB. Do either of the Router USB ports provide power? save to use this port to powe...
- Dec 24, 2020
it should be enough.
My brother uses a rasberry pi 2 off the R7000's usb port with success. the pi zero has lower power requirements.
But the more accessories you add, the higher the power requirements run.
My brothers has nothing connected to it other than power/ethernet.
https://www.raspberrypi.org/documentation/hardware/raspberrypi/power/README.md
Dec 24, 2020Guru - Experienced User
- djchapDec 25, 2020Aspirant
thank you. exactly the info i was looking for
