JoMark65
Jan 30, 2024Aspirant
R7000 with VPN
I have a property in Europe and to watch UK TV whuke there I have set up my R7000 as a second router with Express VPN for routers on it. It works but I do not understand why the download speed for my...
michaelkenward
Jan 30, 2024Guru - Experienced User
Second router?
Two routers on your network can cause headaches. For example, you can end up with local problems with address on your network. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual default IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point (AP) with a wired connection to the main router. Netgear advises this, as does just about every site you will visit.
But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
I suspect that trying to run a VPN on a second router won't work.
