FL2TN
Apr 05, 2017Aspirant
R7000 won't connect to Brother MFC9840CDW printer
I have been unsuccessful connecting my Brother MFC9840CDW to the Netgear. It will show the router on the printer screen, I put in the password in but the printer will not connect to the router. The p...
- May 03, 2017
Hi FL2TN,
1. What is the firmware version of the router?2. Try changing the security option of your 2.4Ghz from AES to TKIP.
VE6CGX
Apr 05, 2017Master
Make sure you have latest driver, firmware for the printer. Also give the printer a fixed ip address. As already mentioned try using WPS method.
