skiisme
Aug 23, 2015Tutor
R7000 won't talk to Ubiguity NanoStation M2 (in wireless bridge mode) at speeds above "up to 54"
My R7000 works perfect with my Ubiquity NanoStation M2 (wireless bridge) when its set to "up to 54Mbps". If I set it at the other 'Modes', e.g., "up to 289" and "up to 600" it will not communicate wi...
- Aug 24, 2015
I can't thank you enough. Not only was the firmware change a very simple process, the R7000 worked perfect without much, if anything, to change. The very best part is that my Ubiquiti NanoStation M2 now works in transparent wireless bridge mode perfectly -- AT ANY SPEED.
My friend, you absolutely nailed it with your sugestion!!! Thank you!
netwrks
Aug 23, 2015Master
Have a look here: This firmware is real easy to load and it has more wireless setting than the stock firmware.
- skiismeAug 24, 2015Tutor
You're very kind. Thank you for the help.
- netwrksAug 24, 2015Master
You're welcome.Hope everything is working now. (hopefully faster!!).
Well, I hope I don't sound smarter than I really am. I'm the guy responsible for holding back the national IQ score. That said, and really only knowing little (contrary to what they teach in school; the less you know the better off you are ;), I assume I'll be able to do this without bricking it....
Wish me luck.
