skiisme's avatar
skiisme
Tutor
Aug 23, 2015
R7000 won't talk to Ubiguity NanoStation M2 (in wireless bridge mode) at speeds above "up to 54"
My R7000 works perfect with my Ubiquity NanoStation M2 (wireless bridge) when its set to "up to 54Mbps". If I set it at the other 'Modes', e.g., "up to 289" and "up to 600" it will not communicate wi...
  • skiisme's avatar
    skiisme
    Aug 24, 2015
    I can't thank you enough. Not only was the firmware change a very simple process, the R7000 worked perfect without much, if anything, to change.  The very best part is that my Ubiquiti NanoStation M2 now works in transparent wireless bridge mode perfectly -- AT ANY SPEED.
    My friend, you absolutely nailed it with your sugestion!!! Thank you!
