skiisme
Aug 23, 2015Tutor
R7000 won't talk to Ubiguity NanoStation M2 (in wireless bridge mode) at speeds above "up to 54"
My R7000 works perfect with my Ubiquity NanoStation M2 (wireless bridge) when its set to "up to 54Mbps". If I set it at the other 'Modes', e.g., "up to 289" and "up to 600" it will not communicate wi...
- Aug 24, 2015
I can't thank you enough. Not only was the firmware change a very simple process, the R7000 worked perfect without much, if anything, to change. The very best part is that my Ubiquiti NanoStation M2 now works in transparent wireless bridge mode perfectly -- AT ANY SPEED.
My friend, you absolutely nailed it with your sugestion!!! Thank you!
skiisme
Aug 24, 2015Tutor
netwrks
Aug 24, 2015Master
Happy it worked out for you. I run that firmware on 2 R7000's and it is very stable.. As long as you follow the instructions, you're good to go! :) Oh, and the logging is meaningful too! As long as you don't enable QoS, CTF will be enbled, and it will br pretty quick!
