Nikolay
Dec 21, 2015Aspirant
R7000 Wrong Date/Time after firmware update
Dear all, Last night I updated my firmware to Firmware Version V1.0.5.48_1.1.79. Unfortunately now the router is unable to update it's date and time. It stays on 01 Jan 2015. I've reset the t...
- May 05, 2016
I tried all the options given on different forums but no luck. Netgear support gave me beta V1.0.5.49_20151208_timesync firmware which fixed the issue.
[Time synchronized with NTP server] Thursday, May 05,2016 15:25:28
[Internet connected] IP address: xx.xx.xx.xx, Thursday, May 05,2016 15:25:28
[Internet disconnected] Thursday, May 05,2016 15:25:27
[Initialized, firmware version: V1.0.5.49v1.7] Thursday, May 05,2016 15:25:20
toka527
Jul 03, 2016Aspirant
Hello, after contacting Netgear support, agreeing to beta, downloading and applying V1.0.5.49_20151208_timesync firmware which is the version I was provided, I now have the right time on my router, and am able to apply a schedule. Thank you very much to Netgear support, I appreciate your help. Please be aware those of you with a similar issue that the latest firmware update did NOT fix this problem. V1.0.5.49_20151208_timesync firmware is considered an earlier version. I note that the firmware versions appear to all be different.
