rldourlain
Nov 12, 2021Aspirant
R7000
WHen I go to my Nighthawk App and look at the Device MAnager, it only shows one connected which appears to be the router it self, based on the IP. It used show 13 connections. I do have service wit...
Nov 12, 2021Guru - Experienced User
What firmware version are you on?
What modem/gateway is it connected to?
rldourlain
MOTOROLA 16x4 Cable Modem, Model MB7420
Firmware V1.0.11.126
- plemansNov 12, 2021Guru - Experienced User
have you tried installing the latest 1.0.11.128 firmware, then doing a factory reset/reinstall?
- rldourlainNov 12, 2021Aspirant
when I search for Firmware in the app, the one you mention is not available, just the one I have.
How do I do the factory reset?
You can get the firmware and manuals here:
https://www.netgear.com/support/product/r7000.aspx
To factory reset, put and hold reset for 7-15 seconds while powered on.
