Den89
Mar 09, 2022Aspirant
R7000
I canlog in to my ADMIN account on laptop but can't login to my Nighthawk app using the same ADMIN credentials. it gives me error on the mobile app.
microchip8
Mar 09, 2022Master
you need to have a registered account on NETGEAR to login into the app, AFAIK
- Den89Mar 09, 2022AspirantThanks,
I do have an netgear account which I ise to log in the app but after that when my router is linked to the app it is requiring another log in using my Admin username. I have am issue during this Admin log in.- plemansMar 09, 2022Guru - Experienced User
the login info is case sensitive.
Make sure you're using lower case admin and not the capital A that you're currently putting in your posts.
Yes, it is all lower case by default on app. Still can’t log in using same password I use on laptop website routerlogin.net
