Den89
Mar 09, 2022Aspirant
R7000
I canlog in to my ADMIN account on laptop but can't login to my Nighthawk app using the same ADMIN credentials. it gives me error on the mobile app.
Den89
Thanks,
I do have an netgear account which I ise to log in the app but after that when my router is linked to the app it is requiring another log in using my Admin username. I have am issue during this Admin log in.
Mar 09, 2022Guru - Experienced User
the login info is case sensitive.
Make sure you're using lower case admin and not the capital A that you're currently putting in your posts.
- Den89Mar 09, 2022AspirantThanks
Yes, it is all lower case by default on app. Still can’t log in using same password I use on laptop website routerlogin.net
