sbtech48
Apr 22, 2022Follower
R7000
There are many issues but they all started about the same time. 1.The Nighthawk app can not connect to the R7000 2.I have a device on the network it does not show up on the Attached Device list but...
Apr 22, 2022Guru - Experienced User
How do you have Basic and Advanced Wireless configured on the router?
2.I have a device on the network it does not show up on the Attached Device list but does show up on the Access Control List.
3.The device is a main water shutoff valve that was working for a few years until recently.
4. Shutoff valve when near the router gets the ip address and shows in the ACL. When I move it to its location it drops off the network.
5.The signal strength where the valve is located is about 87%
6.It has the latest firmware.
Thanks in advance
Also for the NH app, give this a try:
