Boris-R7000Bg
May 28, 2022Tutor
R7000
Hello! I have a problem with my R7000 route! My router started to restart constantly for 1 hour, it restarts at least 12 times and so my internet is interrupted, can anyone help me and tell me how I c...
- May 28, 2022
have you tried factory resetting? (push and hold reset for 7-15 seconds while its powered on)
have you checked its power supply? I've seen someone swap them with their modem and it not have enough power to boot or run under any load.
What firmware version are you on?
May 28, 2022Guru - Experienced User
Boris-R7000Bg
May 28, 2022Tutor
I checked the power supply, everything is fine, I tried and reset several times as you say but nothing works, the router still has the same problems. Today I installed the new update but again nothing changes
- plemansMay 28, 2022Guru - Experienced User
how did you check the power supply?
They're tough to test because without a load on them, they can have proper voltage and its tough to put a load on them and still test them.
what firmware did you install?
what modem/gateway is it connected to?
- Boris-R7000BgMay 28, 2022TutorI put a new power adapter to check if it is from him but the problem continued ... I installed this update 1.0.11.134_10.2.119, I have been using the router for two years and so far I have not had any problems with it it works very well, but since 4-5 months ago it started to cause me these problems, it constantly restarts, I tried everything, I reset the settings, but still the same
- plemansMay 30, 2022Guru - Experienced User
have you tried downgrading the firmware a version?
Any time you downgrade, do a factory reset/reinstall with the r7000
